Bring to font
rustyou
Bring to font
Post by rustyou »
Hello,
In the exemple (schematic1), i would like put à second picture in front and no replace by the second picture.
-----> when i clic on the switch, my second picture hide my knob....
How shall do it?
Thank you,
Schematic1.fsm
Exemple
(159.92 KiB) Downloaded 971 times
Re: Bring to font
...Like this?
Pay attention to trigger order (yellow wires coming out of the visual node).
Schematic1b.fsm
(153.46 KiB) Downloaded 1046 times
Schematic1a.fsm
(153.46 KiB) Downloaded 1010 times
rustyou
Re: Bring to font
Post by rustyou »
Hi !
Perfect ..
Who is the solution.....?
Re: Bring to font
If you look closely at these yellow wires/cables - sometimes they have small black dots on the beginning or at the end. These dots count so called "order of triggering", which means - first, second, third, and so on. First connected is on the bottom. Last connected is on the top. Now if somewhere there is a selector/multiplexer, then this content can be turned off or on, but the content will be always on the same layer.
Just play with connecting these yellow cables (connected to "V" nodes) in various combinations. Redraw module is the last one connected (top layer = refresh all below it).
And don't worry - it took me some time too, to understand that.
rustyou
Re: Bring to font
Post by rustyou »
hi Tester,
Thank you, I just realized !!! :)
It's not easy in the first time ... ^^
