Feature requests
Feature requests
1. API interface for creating FS custom modules as native FS module or import dll written in C or Delphi. That would make FS really unlimited tool, allowing creating any FS module - VST host module for example.
If that is not possible, at least:
2. VST host module. Another thing I'm missing in FS to use it as my main musical IDE is its inability to host other VSTs. So I cannot use it to build my custom VST host. Only custom VST host can give 100% freedom of midi routing.
HiAsm - A Visual Programming IDE for ALL programming languages:
https://hiasm.com
https://hiasm.com
- CoreStylerz
- Contact:
Re: Feature requests
1) is done in last version. You can build and use your own c++ code to build primitives according to the DSP robotics template for Visual c++ 2008.
PM me if you are interested.
2) SM and its evolved form of FS was never intended to be used for the creation of hosts and cant really see anyone adding it as a feature anytime soon! or even anytime ever!
I peronally would hate the world to be given a shake and stir method of creating vst hosts and daws, the pro market is already awash with half arsed attempts at these types of software! and thats me just talking about the main contenders wares!
btw Corestylerz! my version does not have a template that allows you to create primatives! the only template i have with my copy of FS allows you to creat dll files that can be used and embeded into your projects and can, I suppose be loosley interpreted as "custom primatives" so where is the template for primative creation?
Regards
Regards
Yes, I've missed it. That's great! (dll embedding). Thank you for sharing. Even though you still cannot create your primitives, I think FS is simply the best and awesome. Definitely, I'll create my DAW with it some day.))
https://hiasm.com
https://hiasm.com
- CoreStylerz
- Contact:
You cannot make primitves, but you can add your dll.
I see.. If I save my dll within dll component will it emerge in the palette?
And when I tried to open dll template in MS VC++ express 2008 it throws an error:
Jay, I think every musician should know his/her instrument perfectly. But apparently, this is only possible when you create it from scratch..The following error has occurred during XML parsing:
File: C:\Users\Admin\Documents\Visual Studio 2008\Projects\TemplateDll\TemplateDll.vcproj
Line: 5
Column: 7
Error Message:
quote expected.
The file 'C:\Users\Admin\Documents\Visual Studio 2008\Projects\TemplateDll\TemplateDll.vcproj' has failed to load.
https://hiasm.com
https://hiasm.com
open the file TemplateDll.vcproj with an text editor and add the quote in the red line
Name="TemplateDll"
<?xml version="1.0" encoding="Windows-1252"?>
<VisualStudioProject
ProjectType="Visual C++"
Version="9.00"
Name=TemplateDll"
ProjectGUID="{6957056A-AD38-4CB9-A6EA-0C3A611AF10D}"
RootNamespace="ExampleDll"
Name="TemplateDll"
Version="9.00"
Name=TemplateDll"
That easy.) ok, thank you, I'll try that.
I thought it was far more severe compatibility issue.
https://hiasm.com
https://hiasm.com
