Need help. Porta Poly - Slide. Equaliuzer. Distortion.
ISounds
Post by ISounds »
1.Hello guys on Flowstone. Im building a simple synth. And im stuck.
How can i make a portamento with slide effect. Like the one on sylenth 1?
Also is there any way i can make this effect without any porta slide? Like modulation pitch with Mod Env to oscilator?
2.Im using FS equalizer and its lagging when changing the EQ. How can i fix this is there any optimized EQ thats not lagging that works like this?
3.Distortion. The distortion in FS is set to 0-1 and when i connect it to the synth i get 0 sound?
4. I also have a bugg in my mod wheel if some one could help me have a look. I post the FS file for you so you easier can help me.
