Switchable GUI
blatantleesly
Switchable GUI
Hi there,
I'm currently trying to create a switchable GUI box, so to speak. I have looked at Phonics VSTs and trying to pick apart his entrancer VST to see how to create clickable tabs. I have attached a example of what I have been working on. The idea is to learn how to make a part of a plugin that can bring up different pages. I am finding the MGUI/Wireless link thing a bit hard to fathom at the moment so any help with this would be very much appreciated. Can't seem to really find a good starting point for the GUI building.
Kind Regards
Lee
Kind Regards
Lee
Re: Switchable GUI
Ruby Tabs implementation by MyCo
viewtopic.php?f=2&t=1193#p3802
blatantleesly
Re: Switchable GUI
Hi again.
Managed to get it to work on my own before I checked back, How would I go about adding a background bitmap to each pane? I add to one but it shows up in the top module but will not stay in its own pane which is a pain (excuse the pun).
Regards
Regards
deleted by uploader
deleted
Re: Switchable GUI
thats how i normally do it,
you can also set the view which should be active when the app is started (its inside the radio button module).
the difference is that i have an on /off switch inside of each selectabls view which can be activated when its id is selected
instead of having a big selector where all views are connected and what creates a mess with all the different view connections (its a big mess when you have a lot of different views to select) you have just one index selector which sends its index to each view.
- view selection.fsm
- (280.18 KiB) Downloaded 1011 times
deleted by uploader
delete
Re: Switchable GUI
That's what I wanted to realize with Ruby, when reporting the (for me at that time) unexpected behavior a week or so ago.Nubeat7 wrote:thats how i normally do it,
Re: Switchable GUI
ohh, i couldn't follow the intention - now i seetulamide wrote:That's what I wanted to realize with Ruby, when reporting the (for me at that time) unexpected behavior a week or so ago.Nubeat7 wrote:thats how i normally do it,
you are welcome, the other side of this clean "wireless" schematics is that if you don't name and group the things in a proper logical way you will have troubles to find the right module when you have to change something inside, and it starts to be really confusing too !tiffy wrote: Hi Nubeat7, very nice, clean and clever layout. Thank you very much, I did not know it could be done that way.
Re: Switchable GUI
Very neat Nubeat and very useful...
Thanks for sharing that.
