transpose rows into columns
1) How to display whole transposed (rows into colums) matrix?
1a) How to display (as int) amount of columns after transpose?
2) How to approach to this, if input contains rows with different element sizes?
transpose.fsm
(466 Bytes) Downloaded 877 times
Re: transpose rows into columns
Unfortunately flowstone ruby doesn't support standard ruby library, which contains Matrix class. Here is the solution - modified version of what you have in your schematic. It works also with arrays, which have different lengths of lines, or even missing values.
def transpose(matrix)
	#find longest line( to determine number of raws)
	ln=matrix.max{|line1,line2| line1.size<=>line2.size}.size
	trn=Array.new(ln){|i|
	matrix.map{|line| line[i]}
	return trn
asd1 = @in1.map do |row|
row.split('^')
watch "old",asd1
asd2 = transpose(asd1)
watch "new",asd2
output 0, asd2[@in2]
output 1, asd2.map{|line| line.join("^")}
to find the length of the longest line (the number of columns) use:
Thanks KG!
