comparing arrays
comparing arrays
I need some simple code for comparing arrays and getting output with 0/1 values.
example input1:
50
50
50
example input2
40
50
120
output array: 1 if input1>=input2, else 0
0
1
1
Note: basically I will need to extend it into value versus range (to check whether value is within a range specified by two arrays: min and max) and range versus range (to check whether there is a common part between range1 made of min1 and max1 array and range 2 made of min2 and max2 array). Anyone has it perhaps...?
Re: comparing arrays
Okay, the problem I had was with automatic output conversion. Ruby does not donverts booleans to integers, like greenery does.
So here are 3 goodies.
1) simple compare between two arrays (between row elements on two arrays)
2) check if value is within range (detection for array set of course)
3) check if 2 ranges have some common part
compare arrays.fsm
(839 Bytes) Downloaded 918 times
