Trigger LED
Trigger LED
Sometimes it's the small things in life. You probably know the little indicators that light up when the boolean input is true? I needed an indicator that lights up when a trigger arrives, and then shuts off after some time automatically.
You can set the time range, on and off colors in the properties.
Cheers!
Cheers!
- trigger_indicator.fsm
- initial version
- (1.06 KiB) Downloaded 1267 times
Re: Trigger LED
Very nice!
Re: Trigger LED
Interesting to see this in RUBY code. Thanks
