Capturing the pitch band message by Ruby - Is there a way?
http://imgur.com/a/mcz20
Hi people.
Found some free time to try solving this old time problem I have:
I'm still trying to pass a manipulated midi signal (by using Ruby) to the outside world through a virtual midi cable without loosing the pitchband message that being created during playing the keyboard. The first code in the picture manipulates the message fine, but I have no idea how to make ruby pass the pitch messages as well
So I just thought maybe there is a creative way to connect both manipulated and original midi signals to a second ruby module and then isolate only the pitch messages from the original signal, while keeping the manipulated un-touched. When done, the ruby module would create a new midi array that would pass the total results (manipulated notes+pitchband messages) out to the cable.
Any chance that its possible? What would be the code then (I tried so many suggestions allready - yet no luck)? Thanks
Hi people.
Re: Capturing the pitch band message by Ruby - Is there a wa
That sentence doesn't make sense. MIDI is a serial protocol. All messages come in and go out one after the other. So, hitting a key and moving the pitchbend wheel simultanously creates two discrete messages.kortezzzz wrote:When done, the ruby module would create a new midi array that would pass the total results (manipulated notes+pitchband messages) out to the cable.
Seperating pitch bend from the rest of the stream is simple. The status byte is 224 + midi channel (0-based). 224 = pitchbend on channel 1, 239 = pitchbend on channel 16
You just have to check for the status byte to be in that range and then output to another midi stream. Find an example attached. I'm sure you'll figure out the rest
- Filter_Pitchbend.fsm
- (435 Bytes) Downloaded 1021 times
Damn yeah, tula, you did it again!
God, I was after a solution for so long...
Works perfectely here. THANKS MAN
