Ruby constants
MyCo
Re: Ruby constants
Post by MyCo »
I know what self is, this wasn't the question. The question is, why you define a method explicitly with self (which makes it static).
Re: Ruby constants
MyCo wrote:Is it safe to assume, that all RubyEdits are initialized, before they receive external Inputs from other components
I'd want to test some more, but it certainly seems that way - what appears to happen is..
- 'init' run for all RubyEdits
- triggers from any 'output' methods in init get buffered.
- Green starts, and acts on the buffered triggers
- 'event' methods of Rubies act on the triggered data as usual.
I've not yet been able to trip this up by copy/pasting to change the startup order - but, as with you, I have only tried it so far on small schematics with only a few Ruby editors.
MyCo wrote:For the constants problem? From the documentation it looks like this should lock the variable. But in FS, when I try it, I still can change the value. Don't know what's going on there
Yes it's not what I expected either - but it is consistent with Ruby.
Variables are just pointers to objects - so the freeze command doesn't lock the variable, it locks the object to which the variable is pointing. So you can then no longer modify the object by calling its methods - but you can make the variable point to a different object entirely., because the '=' is an assignment, not a method call with the object as its receiver.
MyCo
Re: Ruby constants
Post by MyCo »
I've played around, and it doesn't work in bigger schematics. Looks like the trigger in this case is sent out before other elements are initialized. When the elements get initialized later, they don't even get the last value from the input, instead they used the values that were stored when the schematic was saved.
Re: Ruby constants
MyCo wrote:I've played around, and it doesn't work in bigger schematics
Dammit - I thought it was a bit too good to be true. :(
The only workaround I can see is to use an external trigger (After Load prim' ?) to trigger the value send - or maybe schedule a Ruby event from init to trigger it. But then, of course, you've got to make sure that nothing else reads it before that happens (or at least tests for that case and can handle the exception).
MyCo
Re: Ruby constants
Post by MyCo »
I've already tried the "After Load" that you mentioned. This actually works, but in other RubyEdits you have to make sure, that the callback object is valid. Because there could be other triggered events before the Ruby Callbacks initial "After Load" comes in. Therefor I use "begin... rescue...end".
Re: Ruby constants
MyCo wrote:Callbacks initial "After Load" comes in. Therefor I use "begin... rescue...end".
Yes, I'm starting to feel the need to look into that too - had a few times where resolving execution order was a lot harder than I though it would be.
digitalwhitebyte
Re: Ruby constants
Post by digitalwhitebyte »
MyCo wrote:I know what self is, this wasn't the question. The question is, why you define a method explicitly with self (which makes it static).
def self.Const
1
If you send any message to self (e.g., self.Const) it is calling the Const method of your class.
Const= is just a setter method. If you want Const to be a variable, you must not use self.
MyCo
Re: Ruby constants
Post by MyCo »
As far as I understand it, if you define a method with self, you get a static class method. And actually, you don't need static methods in FS Ruby, unless you want to create multiple instances of a class... which you can't do with RubyEdit.
Here is what I mean:
class Test
	def self.Const
		1
	def Const
		2
watch "static", Test.Const         # outputs 1
watch "instance", Test.new.Const   # outputs 2
MyCo
Re: Ruby constants
Post by MyCo »
Another Ruby question:
Why does the ruby interpreter completely locks up, when you just type:
redo
is there an outer loop, that we can't see?
digitalwhitebyte
Re: Ruby constants
Ruby redo Statement:
Syntax: redo
Restarts this iteration of the most internal loop, without checking loop condition.
Restarts yield or call if called within a block.
