Multiplex/Selector Quirks
Re: Multiplex/Selector Quirks
Multiplexor is definetely wrong... actually 99% of all time multiplexors are used for view (because view operates backwards).
@Nubeat7: You can connect booleans directly into selectors, you don't need "Int select" for converting boolean to integer.
Perfect Human Interface
This is one of those cases where what you see isn't what you get. I don't see how you wouldn't want to use multiplexes in lots of your projects, aside from the problem I identified.MyCo wrote:Multiplexor is definetely wrong... actually 99% of all time multiplexors are used for view (because view operates backwards).
Thanks Nubeat7 very good work easily, i adapted it to my project and its work great
happy new year all!
