Knobs made in blender.
wlangfor@uoguelph.ca
Re: Knobs made in blender.
lalalandsynth wrote:Made this one in Photoshop and After fx. Originally a template , using it to get my skills.
Lalaknob 1.fsm
FS is 64 bit , so I have included the png strip .
You can resize it as needed , it is now 218*196
image1.rar
I am planning to gather more knobs into this post if there is interest.
I did the same tut, but without AE. I like Yours; Thanks. Maybe I'll try this know for My new vocal processor. Your LED's look great :)
My youtube channel: DSPplug
lalalandsynth wrote:Do you have any suggestions Tula for modern designs , I am willing to try making some.
As for the gif vid , I use https://www.cockos.com/licecap/
Gif screencapture.
Thank you, downloaded right away!
Suggestions are difficult, since there are so many ways to give it a certain optic (like flat design, for example). Here are a few screenshots that might inspire you.
https://static1.squarespace.com/static/ ... ormat=750w
https://www.gearslutz.com/board/attachm ... curves.jpg
https://img.wavescdn.com/1lib/images/ho ... mo-vid.jpg
https://www.izotope.com/en/learn/produc ... 002373.png
https://musicproductionnerds.com/wp-con ... ements.jpg
lalalandsynth
Post by lalalandsynth »
Same knob without Leds , grey ring is FS native Vector.
64 bit alpha with Grey vector.
Modified.fsm
(56.03 KiB) Downloaded 951 times
Png Strip 79*79
Stallker 48.rar
(45.41 KiB) Downloaded 968 times
Beautiful screenshot! I love Stalker! (A filtered delay effect?)
lalalandsynth
Its actually an envelope follower with sidechain to control either volume or filter.
Send drums into sidechain , bass into signal and either filter it or control the volume with the drums.
You can set the sensitivity with dragging the threshold line , you can also invert the envelope.
You can use the envelope follower for this or an AR generator derived from the input signal.
The delay is what makes it special as you can delay the sidechain signal for syncopated rhythms , set the dry&wet and even add feedback.
You can also load a wavefile as a modulator , auto synced to tempo.
