Midi note \ chord latch
Re: Midi note \ chord latch
gvalletto wrote:I want to change my nickname and to add a bmp to my profile. How I do it?
You can't change your nickname I'm afraid. The only way is to create a new account. Then you could always add a signature which says who you were before.
To add an image:
- Go to User Control panel
Profile
Edit Avatar
Then you can Browse to your image and upload it. This image can be changed at any time.
Thanks Spogg!!
- Henryenaxy
- Contact:
Midi note chord latch
How do I change what MIDI note AD output ?
When I play the Cymbal I hear Hi-Hat and when I play Hi-Hat I hear Cymbal in my DAW ?
Try replacing your drum synth by another one to see where is the problem.
Also try to replace your drum synth by a melodic synth, like a piano. If you play the correct notes, then the problem may be in the drum synth. Some drum synths bring non standard assignation.
MichaelBenjamin
Last edited by MichaelBenjamin on Mon Sep 21, 2020 9:56 am, edited 1 time in total.
- trogluddite
I've now posted a "MIDI Hold" module which can handle three kinds of MIDI sustain/note-latch. It's in my "MIDI Helpers" schematic which you can find <here>.
Thanks Trogluddite! You are a genius!
That's about the same thing that i'm trying to achieve! That's great, i'll try your version, i made a thread about my version but it provokes "c++" crashes in FL...
