Lfo in ruby
borodadada
Re: Lfo in ruby
Post by borodadada »
No stream, Green circle f :) float. Basic speed static.
demo version ^)
http://rghost.ru/46944750/image.png
Re: Lfo in ruby
Post by Nubeat7 »
:lol: hopefully you didn`t try my code example, i should try the next time.. here is something which works
thru_array.fsm
(427 Bytes) Downloaded 941 times
borodadada
Re: Lfo in ruby
fantastic, thank you
but how change time ? ^)
speed = 0.1 not work :S
Re: Lfo in ruby
Post by Nubeat7 »
itsbecause time % size is the index for the array and this counts only the full numbers - with a speed of 0.1 it is counting 1,1.. 1.2... 1.3... and so on so it counts every 10 steps... just multiply the time with 10 before you do the modulo... or 100 when speed is hundreth...
borodadada
Re: Lfo in ruby
def event i,v,t
v=*(1..1000)
a=*(2..999)
a.reverse!
va = v+a
size = 1998 #arraysize
speed = 0.0101
c = time * 1000
if @on
output 0, va[c%size]
input 100, nil, t + speed
Okey.... modify, work.
Thanks!
