presetmanager bug or normal behaviour?
Re: presetmanager bug or normal behaviour?
just getting to look inside ...
don`t forget to trigger also at the output to update the slider or knob
hmmm ... something I did forget during my attempts :|
The one I need to really look at is your multi-function slider, and now seeing how you've implemented the reset to a defined 'Default' position.
This is a very nice feature to have available for sure.
Last nite I work on an idea to include a 'Message/Alert Box' added to the INIT/Reset button. The idea was to have confirmation that a reset was indeed wanted.
I have posted that addition into the example. I found that this was not as straightforward as I had thought it would be. The MsgBox doesn't have an 'internal' reset of its state, so I had to attach a 'switching' logic to monitor the user choice and only send the 'Reset trigger' on 'YES'. [maybe I made this more complicated than needed, but seems to be working].
Thanks once again NuBeat ! :D
Here's the schematic:
init program+array [with MsgBox - RJH]-1.fsm
(156.04 KiB) Downloaded 850 times
Post by Nubeat7 »
cool, thats a good idea,
you also can modify the ruby trigger button and open the message box directly there..
with the ruby version you can also send just a trigger to the output no need to workaround some states
init program+array+msgbox.fsm
(180.86 KiB) Downloaded 856 times
:o That's all that needed to do this with RUBY !??! :shock:
:lol:
I'm laughing cause of the amount of time it took me to get the PRIM idea working :roll: I'm certain that my prim use was a crude solution, and could be done much simpler ... but this RUBY solution is a far cleaner code. :mrgreen:
Thanks for doing that !
Now to study the multi-preset mod you provided.... that ... and I must keep working RUBY stuff more !
8-)
This is working nice NuBeat ! :D
Even simpler ... having a 'Reset INIT' within a module allows for just that module to be affected. Now, placing another Reset button above all the separate modules, adding a wireless 'masterinit' out, while tagging a wireless 'masterinit' to the trigger of the inside modules now provides for both separate, AND a Master INIT reset. :o We can reset one ... or all.
beautiful :mrgreen:
