mouseMoveCaptured with right mouse button - bug?
Re: mouseMoveCaptured with right mouse button - bug?
billv wrote:
def mouseLDown x,y
   @mouse=0
    captureMouse if @mouse = 0
def mouseRDown x,y
   @mouse=1
    captureMouse if @mouse = 1
def mouseMoveCaptured x,y
       if @mouse==0 then
          output 0,x
   elsif @mouse==1 then
          output 1,y
def mouseLUp x,y
     releaseMouse if @mouse = 0
def mouseRUp x,y
     releaseMouse if @mouse = 1
Don't quite get this. The 'if' statement doesn't check for a value but assigns either 0 or 1 (e.g. @mouse = 1, instead of @mouse == 1). But then you don't need an 'if'. The code line before would be sufficient.
Post by billv »
billv wrote:(e.g. @mouse = 1, instead of @mouse == 1)
yeh...that' parts not needed it seems...and wrong anyway...
Still works fine without it. Thanks..
billv wrote:yeh...I'm not sure why @mouse = 1 works here...still has me thinking a bit.....
That's because "if var = value" isn't an error of any kind. In ruby, var will be assigned the value and then checked if it's true, which is is of course ("var = value" will always be true). It doesn't harm in this case, since you intended to set the var to the value, but
@mouse = 0
captureMouse
is sufficient. And the last two should work with a double equal. Unless there's a severe issue with Ruby in Flowstone...
EDIT: Just saw your edited answer. Wrote this before, so I'll leave it, for others to read^^
Post by billv »
Thanks tulamide
I"m finding the release part is no good as well.....
So I've ended up with this...
def mouseLDown x,y
    @mouse=0
    captureMouse
def mouseRDown x,y
    @mouse=1
    captureMouse
       if @mouse==0 then
          output 0,x
          output 1,y
def mouseLUp x,y
    releaseMouse
    @mouse = 0
def mouseRUp x,y
    releaseMouse
    @mouse = 1
