For those not in the no (Tips and Tricks)
Re: For those not in the no (Tips and Tricks)
Nice one Roxy! Simple but useful.
kortezzzz
Post by kortezzzz »
Here is one of mine:
An advanced drawbars module (***for "blue" source! not poly***), based on fixed points 2 bands EQ. This one stared in one of my releases 2 years a go. It also has built-in right click midi learn feature in every slider and knob. I've designed it for 3 osc. synth, so it actually handles up to 3 mono sources at ones with an option to pass through each osc.\source separately.
Cheers!
( Byron synth drawbars).fsm
(1.2 MiB) Downloaded 1234 times
rocknrollkat
Post by rocknrollkat »
Spogg wrote:Nice one Roxy! Simple but useful.
Thanks, Spogg !!
I am developing test gear and calibration gear to help us keep levels, etc. under control.
This is the gear that nobody needs until they NEED it, and don't HAVE it.
I'll post 'em as I come up with 'em.
For example, it seems like my soundcard clips at just under 2 volts peak to peak with about .01% THD.
I'm making these measurements with a scope that comes from a person in Germany named Christian Zeitnitz.
Here's the link.
https://www.zeitnitz.eu/scope_en
It's free of charge, if you don't already have this scope, I recommend that you treat yourself.
Enjoy !
ROXY
kortezzzz wrote:Here is one of mine:
Cheers!
Nice! You make such good looking stuff. Many thanks for sharing.
Thanks ROXY .... for the link.
Most interested in what you are planning
rocknrollkat
RJHollins wrote:Thanks ROXY .... for the link.
Sure thing, RJ !
ROXY
rocknrollkat
1-5-2015
Here's a handy-dandy 'ganged' pot that you will never need until you NEED one !
Open up the schematic, add or subtract as many 'gangs' as you need.
The best feature of all is that you can set different values for the individual pots !
Let's say you need a 3 gang pot, two gangs to be 0 to 10, the third gong needs to be 0 to 20.
No problem, just enter the values and off you go !
Play with the demonstrator and have fun !
ROXY
ROXYPot-4 gang Demonstrator.fsm
Imagine if you had to buy this custom made in the real world !
(83.1 KiB) Downloaded 1267 times
BobF
Post by BobF »
Hello rocknrollkat,
Thans for the tools (fsm's), they are really great. I myself will use them and I am sure many others will to. You must be the guy I stated this post for, ha, ha. Keep up the great work and keep them comming.
Later then, BobF.....
rocknrollkat
[quote="Spogg"]This simple Level module allows the input stream to be automatically turned off when the knob is at zero, to save cpu when no sound is output.
Spogg, this an extremely Kooool idea !!
I love simple, elegant designs, and this is one of them.
I especially like your 'dummy' load, I've seen simple components, but that takes the cake !!
Best,
Roxy
rocknrollkat
ROXY Organizer Demonstrator - 1-6-2015.fsm
Organize your work and watch your project come to life !
(34.37 KiB) Downloaded 1275 times
BobF wrote:Hello rocknrollkat,
Hello Bob,
Yup, great idea for a topic, thanks for starting it !
I'm glad you enjoy these little ideas.
Here's a set of 'schematics' that go from unreadable (like we usually end up with), to somewhat usable, to elegant.
Many projects become a morass of components, jammed together as needed, and a week later....
WHAT was I thinking ?
The top 'schematic' looks all too familiar.
This simple tip can make or break a project !
Enjoy !
Roxy
