Approximate numbers Help
Re: Approximate numbers Help
hmm, maybe some multiplication and division trick using int?
But Ruby is prolly the way
Yesnix wrote:But Ruby is prolly the way
thats not true, the format string does correct rounding...Nowhk wrote:Anyway, that's won't "round" really to the last digit, just "cut" the string.
this has been discussed several times here on the forum, here is one with different solutions:
http://www.dsprobotics.com/support/view ... 6&start=30
- Float to Decimal Place Converter.fsm
- (399 Bytes) Downloaded 885 times
Oh nice, your example seems to works better. In fact here the rounding is not the expected value:Nubeat7 wrote:thats not true, the format string does correct rounding...Nowhk wrote:Anyway, that's won't "round" really to the last digit, just "cut" the string.
(for you example, 57.783 and not 57.784). Thanks for the tip dude! Another learned thing!
