K5 - Pro Grade Compressor (?)
Rocko
Re: K5 - Pro Grade Compressor (?)
Post by Rocko »
Hey guys,
Sure, re-coding it on 3.08 will take a lot of my time, but I 'owe' it to the forum. I got so many questions answered here, that it would be my pleasure to contribute.
I hope to get to it soon.
Regarding Wassaka'a issue - let me address this with you on PM (private message). On my machine I have opened and closed this FSM file a zillion times without an issue.
Rocko
@Wassaka:
Delete the contents of
C:\Users\<your name>\AppData\Roaming\FlowStone\Recovery
Flowstone should then open ok.
@Rocko:
Since you have used the most recent beta version you can "Save as" and choose the earlier format for 3.08.
Then you open it in 3.08.1 and most of it will work but probably not the DSP code. You will need to copy/paste the beta version code into the 3.08.1 DSP box and re-save. I believe the DSP compiler has been changed for the new beta versions.
Hope this helps.
Wassaka
Post by Wassaka »
Spogg wrote:@Wassaka:
@Rocko:
Hope this helps.
Thanks all of you guys!! I finally reinstall the Flowstone... I don't locate the problem.. Thanks!
Rocko
Post by Rocko »
Thanks all for your help.
I've re-coded it entirely in 3.08 and tested it. Seems very fine.
Here is the new thread with the new 3.08 tested version:
http://www.dsprobotics.com/support/view ... f=3&t=5976
Appreciated
