Random number per Note (code)
Re: Random number per Note (code)
tulamide wrote: I understand. But maybe I misunderstood the use case?
Ahhh!!
I re-read the original post and it could have been understood to mean a change of a modulation parameter every time a new note is played. So I misunderstood your misunderstanding. :lol:
For that case, what you suggested would be fine of course.
TrojakEW
Post by TrojakEW »
Thank you all for all the comments and suggestion. Spogg described the problem I need to solve correctly. Adam assembly code is spot on for my use. Very elegant and simple and as he said using stage 0 there is almost no cpu uasage. So another special thanks to adamszabo.
