Ruby constants
- digitalwhitebyte
Re: Ruby constants
Regarding the use of self
I do not know, maybe I misunderstood what you wanted to do, but what I mean is displayed in the attached file.
- test_const.fsm
- (381 Bytes) Downloaded 1011 times
Re: Ruby constants
I don't get it, what do you want to demonstrate with this?digitalwhitebyte wrote:I do not know, maybe I misunderstood what you wanted to do, but what I mean is displayed in the attached file.
What I wanted was a constant that only exists inside one single RubyEdit... you can do that with a static or an instance method, in this case it doesn't matter. But why use static? it is longer and has no advantage at all
- digitalwhitebyte
Re: Ruby constants
HAHA long debate on the "self"
I know that I tell you, you already know,
but have another point of view on this clarifies the ideas too.
however, I understood this from my readings, in ruby, static method are called class methods
def self.method_name
defines a class method
def method_name
defines an instance method
def method_name
- trogluddite
Re: Ruby constants
If you are within the namespace of a class, then yes that is correct...digitalwhitebyte wrote:def self.method_name
def method_name
class myKlass
# in here, self = myKlass
def self.method
# in here, self = myKlass.
def method
# in here, self=the object instance
endCode: Select all
def self.hello
"hello"
def goodbye
"goodbye"
hello #=> "hello"
goodbye #=> "goodbye"
singleton_methods #=> ":loadState, :saveState, :hello, :goodbye"The class in the RubyEdit instance context is a proxy singleton class for the individual object which inherits from the RubyEdit base class. You can do something similar for any object...
a = "hello"
b = "goodbye"
a.define_singleton_method(:ouch){"a is #{self}, ouch"}
a.ouch #=> "a is hello, ouch"
b.ouch #=> <undefined method "ouch" for "goodbye"; String>This is effectively what is happening when we create a "classless" definition inside a Ruby primitive - everything is executed in the context of the instance, not the class.
This is actually pretty clever work by the DSPr boys - it's what allows every Ruby editor access to all of the built-in methods, while letting us define our own methods which are only visible to the individual primitive.
The next step will be to similarly isolate plugins/schematics from each other to avoid class/nodule sharing- I've emailed Malc with a couple of ideas for how this might be achieved, and he sounded positive about it, so I'm hopeful that we'll see that improved some time soon.
