Bypass On Silence
Re: Bypass On Silence
of course... assembly only thoughFather wrote:How about pack/unpack components? Can we replace them with some code?!
///pack
monoin mono0;
monoin mono1;
monoin mono2;
monoin mono3;
streamout out;
fld mono0[0];
fstp out[0];
fld mono1[0];
fstp out[1];
fld mono2[0];
fstp out[2];
fld mono3[0];
fstp out[3];
///unpack
monoout mono0;
monoout mono1;
monoout mono2;
monoout mono3;
streamin in;
fld in[0];
fstp mono0[0];
fld in[1];
fstp mono1[0];
fld in[2];
fstp mono2[0];
fld in[3];
fstp mono3[0];
So that's how its done. Thanks Bro!
These look delicious!
Hope they are totally safe to use.
Just one thing is missing. The way the are now, they are executed only in stage 2 by default. To make them working in all 4 stages you have to copy the execution code 4 times ad write "stage0;" "stage1;" "stage2;" and "stage3;" before all of them like this:
///pack
monoin mono0;
monoin mono1;
monoin mono2;
monoin mono3;
streamout out;
stage0;
fld mono0[0];
fstp out[0];
fld mono1[0];
fstp out[1];
fld mono2[0];
fstp out[2];
fld mono3[0];
fstp out[3];
stage1;
fld mono0[0];
fstp out[0];
fld mono1[0];
fstp out[1];
fld mono2[0];
fstp out[2];
fld mono3[0];
fstp out[3];
stage2;
fld mono0[0];
fstp out[0];
fld mono1[0];
fstp out[1];
fld mono2[0];
fstp out[2];
fld mono3[0];
fstp out[3];
stage3;
fld mono0[0];
fstp out[0];
fld mono1[0];
fstp out[1];
fld mono2[0];
fstp out[2];
fld mono3[0];
fstp out[3];Re: Bypass On Silence
Got it. I noticed the connection to unpack isn't turning blue when i connect to it, like the standard unpack. Is it OK?
It is probably just a coloring bugFather wrote:Got it. I noticed the connection to unpack isn't turning blue when i connect to it, like the standard unpack. Is it OK?
Happens.KG_is_back wrote:It is probably just a coloring bugFather wrote:Got it. I noticed the connection to unpack isn't turning blue when i connect to it, like the standard unpack. Is it OK?
I used to have an example on the SM WiKi: basically Stream-to-green, If > 0 Then low -> switch off audio.
Someone else on the SM forum had an genius idea to
jmp Re: Bypass On Silence
Jumping individual codes is a time consuming work and the result is never 100% bypass. But when you are using a selector it shuts off the stream and drops everything. As i understood, this only works with a green selector.
