A new chorus-like effect
- martinvicanek
Re: A new chorus-like effect
This one will compile with FS 3.0.6, FS 3.0.8.1 and FS 4.
Note: The string "hop" apparently has a special meaning in FS 4 assembly. Unfortunaltely I use the following syntax a lot in my schematics:
This is OK in FS 3 but not so in FS 4. Simply change both occurrences of "hop" to "hop1" and it wll work in FS 4.
mov eax,ecx; and eax,<2^n - 1>; cmp eax,0; jnz hop;
<hopped code here>
hop:
- wlangfor@uoguelph.ca
- Contact:
Thanks Martin, very slick; I'll try and find a use for it
- martinvicanek
Here is a variant I named "Korus". I like the sound better than Chorous. It uses more than a thousand randomly detuned echos. Check it out and tell me.
Thanks Kevin for the GUI!
- Korus_kbGui2.fsm
- (740.71 KiB) Downloaded 1268 times
(post deleted) I guess Martin didn't think my joke was very funny - sorry.
It’s great and Kevin has made it look really pretty too.
I compared it with the original Chourus and I don’t feel it’s inherently “better” (using my voice as a test source). To my ears it simply sounds different somehow, but it’s no bad thing to have a choice of sound.
Maybe it would be worth having a selector to choose the algorithm…
Brilliant work as always Martin!
Fixed the jittering Rate slider track illumination, centered it's indicator line (now fixed in Chorous as well) and corrected the plugin name to Korus.
I do like this better than Chorous - I'm using it with synths, not voice input, and to my ears, Chorous was adding a slight 'sproing-y' coloration to everything, and this isn't. At low Rate settings and Mix levels, it adds a beautiful, subtly-moving spatialization.
- MV Chorous.fsm
- (414.2 KiB) Downloaded 1229 times
I built the Chorous into my current synth project but found the CPU much higher than the Korus. I was better able to compare the sound between the two and, on a synth, the Korus is just as good to my ears.
So Korus it will be!
Thank you Martin!
Thank you Martin!
- martinvicanek
Yet another Chorus
Yet another chorus effect. This one is pretty much straight forward: a configurable number of echos (up to 100) with random detunig and panning. It is a bit CPU hungry when you go to 100 voices but I like the sound.
- anotherChorus.fsm
- (36.49 KiB) Downloaded 1111 times
You're becoming a regular chorus of choruses!
