I see a steppy line drawing under 60Hz...
Re: I see a steppy line drawing under 60Hz...
Any effort that tries to eliminate a system-wide issue, in this case 'tearing', will fail for any other person and any other application. You can try to find a solution for your plugin on your pc in exactly your configuration, but that''s all. Unless you hook into the system's graphic buffer to prevent the buffer being written while a frame is to be displayed (which is the cause for tearing).
I see boss! So the only way is what you already suggested, and go with OpenGL. But thats a complicated task for just draw a cursor.
I need to achieve many others important task in FlowStone before this
I'll pin it in my future homeworks.
Or maybe draw only a small portion of the progression instead of a whole vertical line (such as the current Graph path processed during the time with a different color, since I'm elaborating an LFO shape).
For curiousity: if you drag fast the cursor inside the Looper/Player by Exo, did you see the same tearing artefact?Tronic wrote:heredo not...
Because It uses the same principle of drawing...
