tiffy
Post by tiffy »
LED's BOOLE, TRIGGER & ANALOG-SCALABLE WITH SELECTABLE RARE COLORS:
LED's Boole, Trigger & Analog Scalable, with Selectable Rare Colors v1.0.fsm
(478.89 KiB) Downloaded 1086 times
Very nice collection Tiffy!
Many thanks for all the stuff you share.
Like the new color LEDs.
Thanks Tiffy 8-)
tiffy
Post by tiffy »
BOOLEAN LATCH (ALT 1) & BOOLEAN LATCH (ALT 2):
Two Alternative Boolean Latches (Alt 1 & Alt 2) to the existing one by someone else floating around somewhere on this Forum.
Boolean Latch (Alt 1) has 5 components inside and its size is 369 Bytes.
Boolean Latch (Alt 2) has 4 components inside and its size is 361 Bytes.
The operation of both Boolean Output Latches (Alt 1 & Alt 2) is the same except for their inner workings that differ.
Both contain a Help file inside.
Latch Boole (Alt 2).fsm
(29.5 KiB) Downloaded 1056 times
Latch Boole (Alt 1).fsm
(29.5 KiB) Downloaded 1039 times
Straight to the Tool Box. Thanks Tiffy !
Always some cool, unique problem solver. Never know when needed. Thankful when they are.
8-)
BobF
Post by BobF »
Hi Tiffy,
Some nice stuff here! Thanks!
BobF.....
tiffy
Post by tiffy »
FREQUENCY MEASUREMENT OF TRIGGERS AND SQUARE WAVE PULSE TRAIN - GREEN:
Frequency Measurement in Hz:
Ticker Frequency - (10 - 1000Hz).
Square Wave Pulse Train Frequency - 5 - 500 Hz.
Both Ticker Frequency and Square Wave Pulse Train frequencies can be measured. Just Click on the Button to change.
The Stock Tick 100 and Tick 25 Primitives are inaccurate, test and see for yourself.
The Ruby Custom Ticker is much more accurate.
Both Tick Stock Primitives, the Ruby Custom Ticker and the Toggle is included for testing purposes only.
Frequency Measurement (Green) v1.5.fsm
(71.81 KiB) Downloaded 1054 times
tiffy
Post by tiffy »
ONE-SHOT WITH TRIGGER 2 BOOLE V1.0:
Occasions arise when a Trigger has to be sent to a Boole Input in order to temporarily activate the Boole.
But a Trigger connected directly to a Boole Input will not Activate the Boole although the Trigger will pass through the Boole.
For occasions like that use this schematic.
One-Shot with Trigger 2 Boole v1.0.fsm
(1.39 KiB) Downloaded 1038 times
tiffy
Post by tiffy »
SOUND ACTIVATED RECORDING SWITCH.
The switch is activated by the sound from the Microphone and stays ON for the predetermined Duration after which it switches OFF Automatically. This process is repeated for every Duration being set. Therefore DS In and DS Out must both be ON (i.e. already inside schematic) and a Microphone plugged into the Soundcard for the Schematic to function. Also, ensure that the Microphone Volume level and Microphone Boost Level in Windows is also properly set.
Sound Activated Recording Switch.fsm
(57.66 KiB) Downloaded 1038 times
tiffy
Post by tiffy »
SOUND ACTIVATED LATCH.
The Latch is activated by the sound from the Microphone and stays ON until it is Reset. Therefore DS In and DS Out must both be ON and a Microphone plugged into the Soundcard for the Schematic to function. Ensure that the Microphone Volume level and Microphone Boost Level in Windows is also properly set.
Sound Activated Latch.fsm
(57.82 KiB) Downloaded 1041 times
