Synthmaker bundle
- martinvicanek
Re: Synthmaker bundle
For what I could see, the SVF3 filters in Multipoly do not hop the coefficients. Haven't checked your other synths, but I am sure they don't hop(128) when modulating at audio rate. Else you'd have noticed.
I think what I'm beginning to realize is that in a few recent cases, I've used a different version of the SVF that I got from somewhere that are not the original SM SVF. Someone wrote a different code but the module's still named "SVF 3" !
Thanks so much for your detective work !
- martinvicanek
Since the SVF3 is so popular I have fixed the tuning. It wasn't off by much, but now it is supposed to be accurate enough to use it as an oscillator. I have also fixed the coeff update code whihc was a bit awkward.
Happy filtering!
Happy filtering!
- SVF3_Filter_optimized_tuning_fixed.fsm
- (2.19 KiB) Downloaded 1076 times
What is the upper left text supposed to say on the Spirit of spirit GUI shown here.
- Untitled 1.jpg (6.69 KiB) Viewed 39109 times
Just noticed more GUI / text problems on spirit of spirit, what is it supposed to say above the grey switch shown here ?
- Untitled 1.jpg (7.28 KiB) Viewed 39108 times
Wow - thanks for doing that !martinvicanek wrote:Since the SVF3 is so popular I have fixed the tuning. It wasn't off by much, but now it is supposed to be accurate enough to use it as an oscillator. I have also fixed the coeff update code whihc was a bit awkward.
Happy filtering!
Thanks for pointing that out - short answer : GUI burn-in issue (as you probably suspected).DrewDale wrote:Just noticed more GUI / text problems on spirit of spirit, what is it supposed to say above the grey switch shown here ?
- long answer : I'd inadvertently left the label in the schematic after doing the burned-in
image containing all the unusual text. Since it was superimposed on the burned-in
image and my computer was rendering the schematic label correctly, the label was not
visible. Since your computer was rendering that text with a different font you got the
scrambled appearance - two fonts on top of each other.
Fixed now : https://www.dropbox.com/sh/eh0xrbsqnao1 ... eH0na?dl=0
I don't suppose you still have Synthmaker lying around to save that with ? I don't have FS.martinvicanek wrote:Since the SVF3 is so popular I have fixed the tuning. It wasn't off by much, but now it is supposed to be accurate enough to use it as an oscillator. I have also fixed the coeff update code whihc was a bit awkward.
Happy filtering!
Or maybe just post the code and I can paste it in.
Thanks again.
- martinvicanek
Here you go
- SVF3 tuning fixed.osm
- (2.13 KiB) Downloaded 1053 times
You are a prince - thank you so much.
