Flowstone Guru Blog
Re: Flowstone Guru Blog
Thanks KG !
Good start already ... look forward to learning :D
8-)
second part is out :Basics and SSE
Covers the basics (syntax, coloring etc.) along with SSE operations.
Exo
Post by Exo »
KG_is_back wrote:second part is out :Basics and SSE
Really great work thanks for these :) I have learnt a few things I didn't know.
djbrynte
Post by djbrynte »
great site
A guide to asm for people like me? Explaining every aspect? Keeping the decriptions as easy as possible? That's awesome! Much appreciated! Thank you!
+1, thumbs up, KG!
OK people, time for part 3: part 3: ALU, FPU and array management
This part will show you how is data stored in your RAM and how to get it in or out of it using FPU and ALU units of your CPU. This article is slightly more complicated and longer than the previous one and largely builds upon knowledge form the previous ones - make sure you read them and understand them. Also, this time individual ALU and FPU operations are not shown (only few examples), so make sure you check the opcode reference.
Tomorrow I'll release the last part which will be about jumps - a way the CPU implements branching (if else statements), looping (both static loops, "for" loops, "while" loops and "repeat until" loops) and hoping.
The last part jumps (code branching and looping) is out.
This part covers how to implement branching, and all kinds of loops (static loops like in Code component, "for" loops, "while" loops, "repeat until" loops) and hops (both static as in Code component and "smart" using "if" "else" type of statement)
Hope you enjoyed the "How to use Assembler?" series and learned something new ;) have a good day(s and nights) coding...
Exo
Post by Exo »
KG_is_back wrote:The last part jumps (code branching and looping) is out.
I have certainly enjoyed them thanks!
This is now the "go to" series for anybody learning ASM in Flowstone :)
Exo
Post by Exo »
Also just a note to anyone visiting the download area, screenshots for downloads are currently not showing there is a problem with the plugin.
Although new screenshots can be added, I have contacted the developer to see what is best way to deal with this might end up with screenshots needing to be re-added but I will keep you informed on that (I would obviously prefer the problem to be fixed if possible)
