Synth: X11
Re: New Synth: X11
Post by billv »
X11 Updated to 2.10..(Download from first post)
* Tempo automation was out of time...Fixed
* Noise Osc Ticker Send not routed properly.. Fixed
* PM Mod was 1 step out of time..Fixed
* Delay Mod was 1 step out of time..Fixed
Re-installed previous timer, last one didn't make it....
So looping using the start/finish is a bit dodgy again.
Re: Synth: X11
Post by billv »
Just a quick note:
The current version of X11(2.10) was made in 3.03 Raindrop.
I've loaded the X11 into 3.06 Pebble, and found a "NEW" major bug.
A selector I designed called "Easymod" stopped working. There's around 25 in the synth.
So somewhere in-between 3.04 bluebird and 3.06 Pebble, the changes in
FS have made this selector faulty.(Obviously, the design of the selector is responsible too)
This all means a lot of things to me..but to summarize...ATM..
1. If you load the X11 into 3.04 Bluebird or higher...sorry..no guarantees,
I'm not sure at what point of FS Updates has caused selectors to mal-function.
2. if you need to make exe or vst, download online versions from link below
They work fine.(or use 3.03 raindrop for export)
Re: Synth: X11
Post by billv »
Hey Guys,
The original X11 that was built in SM, is now available for download. See first post...
It dosn't have the Ruby accuracy but sometimes this is a real bonus.
It runs on the old timer system I think I stole from myco.
This slight in-accurracy in timing creates a cool "human" feel.
While making music, I find myself prefering the SM version of X11 than the FS version.
So I figure is good to share it again.
Also has a few things the FS version dosn't, like...X-box control and a fishtank. :D
Re: Synth: X11
Post by billv »
I have added a 64 Bit VST2 Plug in in the 1st post. :D
There is also shitloads of Branded merchandise for the X11 available at me home site.
https://www.bvmusicsydneyaustralia.com/
deraudrl
Re: Synth: X11
Post by deraudrl »
I'm getting an error when attempting download using Chrome (all three links):
"secure1.storegate.com redirected you too many times".
Re: Synth: X11
Post by billv »
Thanks...I'm looking into the problem. I tried the links...the first two didn't work but the
3rd link for the 64 Bit plug in ok. It worked in Chrome, Edge, and my AVG Secure Browser.
Looks like I have to generate some new links for the FSM and OSM,as they are very old.
I'll get back to you shortly. :)
EDIT:
All links are working now.. :D ..let me know if you have any problems with the download..
deraudrl
Re: Synth: X11
Post by deraudrl »
Ok, got 'em now.
