Reducing floats to cents to display
CoreStylerz
Contact:
Post by CoreStylerz »
I want to reduce the output display of knob values.
I tried with string extract but to works also with negative values i have to use logic.
Is possibile to do such things with string format primitive.
Since i want values like 0,00 and -0,00
Any help?
PM me if you are interested.
KG_is_back
Re: Reducing floats to cents to display
Post by KG_is_back »
This is implemented in float label in synthmaker. If you have it copy it from there...
the specification string looks something like this: number for example 5.468464
%.2f - rounds number to two decimal places - example: "5.47"
%8.2f - displays 8 chars (padded with spaces) with two decimal places - example: " 5.47" (notice the 4 spaces before the 5... decimal dot is consider a char too)
%08.2f - displays 8 chars (padded with zeroes) with two decimal places - example: "00005.47"
CoreStylerz
Contact:
Ty, i've downloaded back synthmaker. ;)
tester
Post by tester »
...and you use format string primitive for that (or ruby), connected to label via string connector. Trog wrote here sometime ago how to format values in ruby boxes (format defs can be provided from outside). Search the forum here or via google (since searching isn't/wasn't working correctly) - keywords like format string array.
CoreStylerz
Contact:
With ruby should be easy, i've use the old module it works good. ;)
Contact:
Post by Nubeat7 »
its about the same in ruby..
val_string = "%0.2f"%@value.to_s
CoreStylerz
Contact:
Ty nubeat,
The primite works but seems to be buggy and unstable. It's stable but if i put some wrong tags it crashes flowstone... :o
tester
Post by tester »
1) Put right tags into string primitive.
2) Connect the string primitive to format prim.
3) Make a module and add to the toolbox.
Usually you will use always the same stuff, maybe different numbers.
Format prim was always crashing (also synthmaker) when connected to bad tags. But if using correct tags - it works fine.
CoreStylerz
Contact:
tester wrote:1) Put right tags into string primitive.
thanks
billv
Contact:
Post by billv »
Would "round" help here...
1.234567.round(2)  #=> 1.23
1.234567.round(3)  #=> 1.235
1.234567.round(4)  #=> 1.2346
1.234567.round(5)  #=> 1.23457
http://ruby-doc.org/core-2.1.2/Float.html
