Need some help with oscilator.
ISounds
Contact:
Post by ISounds »
I dont wana upload the synth right here. But if you know how to fix this let me know.
I have 2 oscilators and 58 waveforms.
And you can draw what ever you want of those 58 waveforms.
Problem is When i use a waveforms and then draw something. When i save and open project it gets back to that waveform it was before.
So somehow i need to make something like when you draw it doesent jump back to that waveform?
Pls help me out bros.
ISounds
Contact:
Re: Need some help with oscilator.
Post by ISounds »
seem like the forum is kinda dead actually!
Here is the oscilator i need so when i change the wavefrom drawing it. It will get saved like when i load project open the synth again it should be the last used waveform. Like normal.
Oscilator.fsm
(484.26 KiB) Downloaded 890 times
ISounds
Contact:
Post by ISounds »
Bump.
Exo
Contact:
Post by Exo »
Hey, I made a quick modification of your schematic....
Oscilator ExoEdit.fsm
(487.86 KiB) Downloaded 938 times
That should behave how you want. I made a module that you will have to copy and paste for each waveform and then set the waveform index via the properties of the module, you will see what I mean when you open the file.
Only problem is presets, I'm assuming you want to save every edit in the presets too? That would mean having a "Preset Parameter array" for every waveform. 58 is a lot and would make your presets big which could affect load times and preset changing speed, although you will have to test that because it might be OK for you.
If I was you I would have say 10 slots which the user can blend through, then the user can set each slot to any of the 58 waveforms. Then you only have 10 waveforms that need to be saved in the presets.
