How to retrigger a float (out) with same value?
Nowhk
Post by Nowhk »
Ive a float that output to my DAW using the module "Controller".
The fact is that if I have a value on it, and I try to output the same value, the control wont change.
Let say I've a float 0.5 (which set my knob to the middle during play), if I stop daw and I change the knob manually, when I restart daw (is playing) it should retrigger 0.5, and re align the knob to the middle. Instead, till the value on float module change (0.51 for example), the knob is frozen.
Any idea?
Contact:
Re: How to retrigger a float (out) with same value?
Post by Nubeat7 »
then you need to retrigger it using the "is playing" primitive...
Nowhk
Post by Nowhk »
Nubeat7 wrote:then you need to retrigger it using the "is playing" primitive...
What do you mean with "retrigger it using is playing"? If I link "is playing" to the float I want to retrigger, it resets its value to 0 (if stopped) or 1 (if playing):
Maybe I don't have understand what you mean, sorry :o :shock:
Tronic
Post by Tronic »
Excuse me, but let me ask you a few things:
Your knobs are not set up to receive the value when you move it from your DAW?
If not I believe your system has no real use,
because it is supposed that you can control the value also from the automation track,
so it should get the value if you move it from the GUI or from the automation track.
That said,
if you still want the function that you ask,
the primitive "is Playing" must generate a trig and connecting it (adding it) where you have the output value.
Nowhk
Post by Nowhk »
Tronic wrote:Excuse me, but let me ask you a few things:
That said,
No. My plug output to the daw and stop. If I stop it and I edit the knob, when I restart it must re align the knob at state 0 value. But if the float has already that value, it doesnt refresh. Do you see?
Tronic
Post by Tronic »
Nowhk
Post by Nowhk »
Tronic wrote:
The attachment this.png is no longer available
No man, it doesn't refresh :o
Here an example. My plug linked to the Volume knob of Fruity send.
If I manually write 0.5 (from 0, so different value) and I click enter on the Float module, I get the movement of the knob to the middle:
Now, if I manually move the fruity knob (with mouse) to another value (0.7 for example), and I play my DAW, it doesn't retrigger 0.5 to the knob (neither using your method above with trigger):
The knob keep to 0.7.
That's because the float module has not changed.
If I manually wrote 0.50001, it send again "0.5" (even if its not exactly 0.5, but 0.50001).
i.e. I'm still not able to retrigger the "same value", even using your method :(
Nowhk
Post by Nowhk »
No way guys? Happy new year!
Post by tulamide »
I don't have that controller prim, it seems to be FL Studio specific.
The circuit from Tronic is correct, so the issue could be either the controller prim, or the recognizing of the DAW playing.
Create a boolean. Connect the boolean output of the "Is playing" prim with the boolean. Everytime you stop and then start again, the boolean should switch to false and then back to true. Is it so?
If the answer is yes, the issue is related to the controller prim. You said it is reacting to a change when you do it manually.
Create a second float, set it to 0.5, but don't connect it to the controller prim. Stop your DAW. Now remove the links to the controller's value input and connect the second float to it. Does "fruity send" switch back to 0.5?
If not, then it is an issue with the controller prim, that we can't help with. You should report it as a bug then.
If yes, it might just be a timing issue and the trigger might just be delayed to work. But first check all the above.
Nowhk
Post by Nowhk »
tulamide wrote:Create a boolean. Connect the boolean output of the "Is playing" prim with the boolean. Everytime you stop and then start again, the boolean should switch to false and then back to true. Is it so?
Yes it is.
tulamide wrote:Create a second float, set it to 0.5, but don't connect it to the controller prim. Stop your DAW. Now remove the links to the controller's value input and connect the second float to it. Does "fruity send" switch back to 0.5?
No it doesnt.
tulamide wrote:You should report it as a bug then.
Ok so its the Controller prim the problem. Where do I report it as bug?
