Irregular Sine Waves
Re: Irregular Sine Waves
Hello, tulamide. I too think so. the green is somewhat noisy when changing parameters.tulamide wrote: Maybe some of the pros could do a dsp-version of it?
- martinvicanek
Re: Calling out for Martin!
No need to feel embarrased, FS is sometimes quite peculiar. I can't tell exactly what was the issue, probably some connector had some garbage in its memory. Sometimes removing a connection and connecting again helps, even if the connector appears to have the right data type. Anyways, this one should work now.tulamide wrote:Martin,
it's so embarrassing, but I can't get sound of the "pwm"-sine generator, if I use an lfo instead of any green. Could you take a look at what is happening? I don't understand it.
- mod_input_issue_gone.fsm
- (36.88 KiB) Downloaded 954 times
Thanks a lot! I still have no clue what happened, but your version works well. You are probably right about FS.martinvicanek wrote:No need to feel embarrased, FS is sometimes quite peculiar. I can't tell exactly what was the issue, probably some connector had some garbage in its memory. Sometimes removing a connection and connecting again helps, even if the connector appears to have the right data type. Anyways, this one should work now.tulamide wrote:Martin,
Not sure if anyone is interested in, but I made a quick mp3, demonstrating the oscillator in action. No editing or mastering, no effects, just the oscillator with its "pulse width" modulated by hand as well as by two serial LFOs.
This sounds so awesome! I can't wait to build a synth based on it.
First impression.mp3
Lovely sounds!tulamide wrote:Not sure if anyone is interested in, but I made a quick mp3, demonstrating the oscillator in action. No editing or mastering, no effects, just the oscillator with its "pulse width" modulated by hand as well as by two serial LFOs.
Nice piece of music too: less is more and this proves it. Great haunting tune.
This would qualify as the first post into my Flowstone Music Topic...
Hi tulamide,
I also like it. Can of reminds of a a wah wah pedal as the sound is being modulated and the harmonics come in and out. The piece is also nice and kind of tranquil. I put it on my smart phone and also my mp3 player I use in the auto.. Thanks and keep up the great work!
Later then, BobF.....
Spogg, thank you very much!
BobF,
at first I wanted to talk it down. That's my reaction most all the time. Whatever I do, I always think it is not worth a compliment. As if it were nothing of real effort or anything special.
But the truth is: I need confirmation! I need it more than I want to admit. If I just accept that you liked it, even use it on your phone, then it feels just good.
I'm not sure if people can follow my sick thoughts, but when reading your and Spogg's lines, the first voice in my mind said: "They are just trying to be nice. It can't be good. It's just a very simple melody, repeating itself transposed by a perfect fifth, and the bass line is not even rythmic."
And that's always the case. Whatever I do, there's always this voice in my mind that tells me how awful, simple, boring or ridiculous my work is.
I'm slowly learning to accept people enjoying my creations and to allow the joy that their enjoyment brings to me. So, thank you!
BobF,
