Time Primitive - Month Error
NOTE:
The Time Primitive display at its output terminal that the Month January begin at Index 0, but in fact its output terminal produces a numeral 1 for the Index of January.
Therefore, if you construct your Month Array with Jan, Feb, Mar, Apr, May...then the String GetAt will never find January which is in fact at Index 0 in the array, whilst the Index from the Time Primitive output terminal is a numeral 1 for January...thus, all the Months will be 1 Month ahead of time with respect to the Array Index.
You will therefore have to take this into account and make the necessary correction between Time Primitive output terminal and the String GetAt Input Index terminal - see attached Schematic.
- Time Module (Error Correction).fsm
- (1.34 KiB) Downloaded 982 times
Re: Time Primitive - Month Error
Hey thanks for the heads up on that one Tiffy!
Interesting find Tiffy.
For my last project, I used RUBY
I just check it ... was correct.
still ... thanks for the heads-up correction.
Time.now.strftime("%b")still ... thanks for the heads-up correction.
i'm sure its intended to be 1-12 which is logical when using just numbers to show the date, like this you can use the output without any correction.
anyways the descriptions on the module needs to be corrected.
