Blue One-Shot or Mono-Stable
BobF
Post by BobF »
BobsLoopedOneshots.fsm
(514.91 KiB) Downloaded 1872 times
Hello Gang,
Here is a blue mono-stable or one-shot for you all to play with. The loop is for demo only, just to show off some of its timing functionality. There are two trigger inputs, one for positive going triggers and one for negative going triggers. The non-invert/invert must be green to use the negative trigger. There are three outputs, one is the Resistor/Capacitor output and the other two are a positive output and a negative output. The trigger button does just that, it triggers the one-shot. You select the timing via the Resistor and Capacitor value selectors. There is also a knob for fine tuning your timing if needed. I have selected a fairly wide range of values, but of course you can go inside the schematic and make changes as you desire. The looped demo locked up on my pc every once in a while, but NOT often. If it DOES, just break the loop and then reconnect it.
Hope you enjoy this and can find some uses for it. PLEASE if you do find some great uses for it, or make any mods or corrections, or have questions please post them. One great mod would be to calibrate the timing if anyone would like to take on that challenge.
Till next time, BobF....
