Error when i try to create a vst or a .exe(standalone)
leandroseibel
Post by leandroseibel »
Error text
Error text
Hi guys. I know and create vst or standalone since synthmaker times. But now i have problems to create my own effect. Someone could help me? The effect run on flowstone but when i export to VST or .EXE and run the aplication or .dll happen the same error text.
Re: Error when i try to create a vst or a .exe(standalone)
Hello! I see you joined the forum 16 years ago and this is your first post! What kept you? :lol:
Seriously now, I don’t know what this could be but as a start we would like to see the schematic if possible. Also what version of FS are you using? Hopefully not the 3.09 betas available on this site.
leandroseibel
What kept me? Maybe because synthmaker and synthedit are today in 2023 the only 02 softwares that make easily a real vst plugin...
Talking seriously, my version of flowstone is a old 3.01 snowflake! The effect is a junction of models maded by users of dsp robotics forum with some simple mods and logic that i have maded.
Is a simple wave player with impulse response loader to make the Riaa REVERSE curve for cut or emboss vinyl disc's! I have 02 vinyl lathe at home and before you record we have to prepare the audio file.
This plugin make easily all the process of riaa reverse curve and make all freq. below150hz keeping mono because this process(cut or embossing) need this detail .
Live long and prosper!!
Schematic's
Schematic's
Riaa reverse  curve effect for cut or embossing
plugin skin.PNG (359.1 KiB) Viewed 21207 times
leandroseibel
Hi spogg! Its running now. I just install a recent version of flowstone (3.0.8.1) and the .exe is complete functionally! And dont worry, now i will make more presence on forum. I have old project's( synthmaker and flowstone) to post . Simple ideas of a guitar amp.
LIVE LONG AND PROSPER!
runnig now! .jpg (83.15 KiB) Viewed 21193 times
Brilliant! :D
You have a vinyl lathe too! :o
I’ve often wondered if the RIAA processing itself contributed to what some people love about the “vinyl” sound. I guess it must have some influence. Have you ever taken your processed sound and passed it back through RIAA equalisation (not via vinyl) to see what the effect is?
I should mention that we (us users) recommend using version 3.06 for various reasons, unless you need the additional ASM features of 3.08.1
Looking forward to seeing you around a bit more! ;)
juha_tp
Post by juha_tp »
leandroseibel wrote: ...
Hmm... why IR and not IIR?
Also, do you support all commonly used sample rates (CD to DSD) ?
