Click/Pop Problem With Synth
Drnkhobo
Post by Drnkhobo »
Hey guys!
Ive got a REALLY simple synth here and im getting annoying clicks at the end of the voice.
As you will see I have an adsr connected with a bit of a release but im still getting clicks.
Im kinda scratching my head here like I dont know why this is still happening after an envelope
but im thinking its one of those times where the answer is so simple & under my nose. . . .
Anyway, id appreciate it if someone can take a look at my schm.
EZSynth.fsm
Like I said BASIC
(38.93 KiB) Downloaded 1037 times
Oh, should mention , repeatedly press "x" on the keyboard to hear a really good example of the click
TrojakEW
Re: Click/Pop Problem With Synth
Post by TrojakEW »
Hi
I'v checked your synth and with your release setting I din't hear any clicks. To avoid clicks when release is set to minimum you have to edit code to setup minimum value. Check schematic where I have added another adsr with adjusted release. I also added selector so you can switch between them to hear difference. If this is what you mean then adjust it to your need.
EZSynth_adsr.fsm
(40.56 KiB) Downloaded 1001 times
Drnkhobo
Post by Drnkhobo »
I've modified the envelopes already, but I was talking about when you repeatedly play notes , but I seemed to have fixed it in the midi2poly prim options. Retrig stolen ect.
