HELP double selection needed to trigger
rockaxe55
Post by rockaxe55 »
in the schematic the selector needs the items selected TWICE befor it loads the correct float value, how do i make it work with one selection, and am i missing somthing?? any help is greatly apreciated
array generator help.fsm
(132.12 KiB) Downloaded 1092 times
chackl
Re: HELP double selection needed to trigger
Post by chackl »
Hello!
You had a trigger problem ;)
If you read out with the stringtrigger the trigger will:
readout the array and change the index - so the correct value is read out if you send the next trigger (your 2nd selection in selector)
So to get it corregted you allways have to:
Change index - then "Get" trigger.
I have the corrected version here ;)
array generator help-corrected.fsm
(131.74 KiB) Downloaded 1019 times
rockaxe55
Post by rockaxe55 »
thankyou chackl, for such a fast response, your help is much apreciated
chackl
Post by chackl »
you'r welcome ;)
