A little Hand notepad
Tepeix
Post by Tepeix »
A little hand notepad.
Sometime, i get idea that i want to note but it need some graphic.
I could write it on a paper, but the paper have chance to get lost with other ones.
It's more easy to have those note inside the flowstone schematic they are related.
So i build this very simple notepad.. It could be perfected but do the job.
The graphic will stay in memory but is erased when resizing the window.
It's also possible to erase part with Ctrl down.
handnotepad.fsm
(16.8 KiB) Downloaded 523 times
Re: A little Hand notepad
Post by billv »
It reminds me of my Pixel Art Program....
http://www.dsprobotics.com/support/view ... art#p16138
Tepeix
Post by Tepeix »
Interesting and very more advanced !
But for fast notation i stay on mine, even if there's a lot to perfect..
But i'm happy with this new version. Schematic are better organised.
Write are more smooth, combining an ellipse and a line.
And some color selection using shift key.)
Hanpadd2.fsm
(7.94 KiB) Downloaded 517 times
Post by billv »
First thing i did was to test your mouse capture, by drawing really fast..and holy f##K...it works.. :o
Unbelievable!...I say this because i went to hell and back trying to get accurate mouse capture in Pixel Art.
Trog gave me all this "Psuedo code"....it was a real "head f@@k..i'll never forget it...So well done... :D
Tepeix
Post by Tepeix »
Yep, line + ellipse works fine !)
I try to upgrade it, making only ellipse or line depending on the distance..
But finally it's better to always have both of them.
My error was to use different size, for some reason i was thinking it was necessary,
but they merge even better with the same.
Also a little upgrade, we could also change the size of the line using shift and drag.
handPadd V3.fsm
(36.21 KiB) Downloaded 534 times
