PWESynthMaker Projects
pwesynthmaker
Post by pwesynthmaker »
PLEASE TAKE THE TIME TO READ THIS FOLOWUP FOR THE BENEFIT OF "FLOWSTONING" AT ITS BEST!
NOTE: All PWESynthmaker FSM (FlowStone Schematics) Files are created with Flowstone v3.0.6 'Pebble'
including 'standalone executable' effects/instruments for legacy compatibility.
Executables are also created with v3.0.6
There are optionally 3 .fsm schematic versions with different file names.
The main container module ID tag name (top left corner) for all three is the same.
The three different actual filenames *.FSM are each for specific different use.
EXAMPLES:
FlowStone Schematic filename_tst.fsm
This schematic file normally has audio/midi in/out connectors and addtional
test equipment mods for realtime testing within the Flowstone Program.
FlowStone Schematic filename_vst.fsm (or "_vsti.fsm" for midi instruments)
This schematic .fsm file has been re-sized to allow fit within a host DAW
(Digital Audio Workstation). Large modules are significantly reduced to maintain
visibility of and accessibility to a host DAW controls.
FlowStone Schematic filename_exe.fsm (for export as standalone executable).
MPORTANT!
With the exception of an additional folder named "v3.06x86_32bit"
containing one legacy VST2 .dll exported with Flowstone v3.0.6 'Pebble'
all other VST2 and VST3 Plugins (both 32bit & 64bit *.dll and *.vst3)
are now exported with FlowStone Alpha v3.0.9b2-3484-g7792583 ...
The files are not modified or saved in the Alpha version, only exported as
plugins. This allows re-opening same in v3.0.6 or higher.
Updated VST & VSTi Plugins with significant changes are created with
new 32-bit ID (4-character alpha-symbol-numeric format) for VST2s.
Also, a new GUID is generated for VST3s.
BEFORE REPLACING AN OLDER VERSION VST/VSTI PLUGIN:
It is advisable to backup the previous version of a plugin by storing it in a separate
folder inaccessible to the DAW's plugin scanner (such as "Documents").
Then replace the old with new rather than overwriting the old version.
This will ensure a 'new vst scan' is accepted in most DAWs and in the event of
non-functionality the previous version can then be reverted to.
USE THIS METHOD ALSO FOR NEW INSTALLED STANDALONE EXECUTABLES.
Last edited by pwesynthmaker on Sun Feb 09, 2025 12:44 pm, edited 44 times in total.
Inventor eFX Technology
Re: PWESynthMaker Returns!
Post by k brown »
That "See links here" link doesn't go anywhere . . .
Welcome back pwesynthmaker !
Will check out.
Thanks!
pwesynthmaker
Link is now functional.
Apparently necessary to logout, go to page, copy url, signin and paste in url tags.
Or, while logged in ssl redirect displays an admin secured addrress.
pwesynthmaker
IMPORTANT UPDATE!
I have updated my bpm sync echo mods.
The delay and ratio selection menus were edited to
limit the minimum/maximum decay times to
within acceptable tolerances.
This is the post link that contains download info:
FSM Schematics & Toolbox Files
http://www.dsprobotics.com/support/view ... =3&t=64021
For those whom have FlowStone v3.0.6 or higher who have downloaded
any of these projects the echo can been dropped in ffom the audioefx.fsm
in the download.
As of now I am in the process of replacing these mods
in all projects with same and will post the updated download links.
A.S.A.P.
