Trigger A Wave File
Trigger A Wave File
Could one of you show or create for me a simple schematic that triggers a wave file sample? Not using "Playsound" but trigger a sound that will play a sample on demand and output to the plugin audio outputs. I've looked over a bunch of schematics and I can't figure it out.
Keyuword is "simple", using a minimum amount of objects to trigger a wave file sample (like a drum sample).
Thanks in advance.
Thanks in advance.
Re: Trigger A Wave File
There is already the "Wave Player" module, which does exactly that
Which is my point, that I don't know how to use it. How would I play / trigger a wave file to play with it? The documentation doesn't really explain that.adamszabo wrote:There is already the "Wave Player" module, which does exactly that
- martinvicanek
Do you want to trigger it with a certain key (like c2 for bass drum), or is it a pitched sample that you want to play chromatically, or just a button to play one shot at the recorded speed?
Trigger with a midi note, yes.
- martinvicanek
The attached schem will play an audio sample triggered by a MIDI note. I the Wave Player properties, you can activate the option to follow the pitch.
- SamplePlayer.fsm
- (183.72 KiB) Downloaded 1138 times
