Training AI to understand FSR
You may have noticed that your AI is hopeless when it comes to FS Ruby.
The solution is to write your own API, so the AI can understand.
Its not that hard, only takes a few hours.
It practically removes all syntax errors and false method calls,for eg.
Here's the one I built (bear in mind, it is built for me, and not you)
I highly recommend you build your own so it fits "Your" Ruby personality.
Then your AI will spit nice FSR code that is to your liking.
# FSR BRAIN API— BY BILL VALIONTIS
# Flostone Ruby is a HOSTILE enviroment. Do not deviate from this API.
# ------------------API RULES AND REGULATIONS
# Code to written in same order
# Hard boot/init/nilerrors/events/methods/tick/mouse+keys/draw
# All code to seperated by comments and titles
# Always print out full code on rubyedit, unless I ask for a snippet
# Every time you print full code, give it a title and number like Breakout_01
# Avoid using local variable and use Instance variables instead
# Avoid hash usage
# Avoid for-loops
# Prefer 4.times do |i|
# All colors external
# Restart logic must work from beginning of build
# Troubleshoot correct subsystem only
# Never deviate from API
# ------------------INPUTS AND OUTPUTS
# input 0, View (View is refreshed by external ticker)
# input 1, Trig (Reset)
# input 2, Boolean (On/Off)
# input 3, Color @col1
# input 4, Color @col2
# input 5, Color @col3
# input 6, Color @col4
# input 7, Color @col5
# input 8, Color @col6
# There is NO "Puts" or "Print" in this language.
# output 0, "Example string"
# output 1, "Example string"
# ------------------MIDI
# Midi must be written in codeblock def event i,v,t
def event i,v,t
on = Midi.new 144, 1, 60, 100
off = Midi.new 128, 1, 60, 100
output 0, on
output 0, off, t + 0.25
# ------------------TICK
TICK_RATE = 0.25
def init
@angle = 0.0
scheduleMethod 'tick', time + TICK_RATE
def tick
redraw
# ------------------MOUSE AND KEYBOARD
def isInMousePoint x,y #-- Mandatory
def mouseLDown x,y
captureMouse
def mouseMoveCaptured x,y
output [x,y]
def mouseLUp x,y
releaseMouse
# ----------------------KEYBOARD--------------------------
if isKeyPressed(32)
output 0, "Spacebar"
# ------------------HARD BOOT
def hard_boot
@boot = true
def draw(v)
hard_boot unless @boot
# ------------------ARRAYS
# 1. Adding & Removing Elements
# These are essential for managing data streams coming from Flowstone's inputs.
# push(obj) or <<: Adds an item to the end.
# pop: Removes and returns the last item.
# unshift(obj): Adds an item to the beginning.
# shift: Removes and returns the first item.
# insert(index, obj): Inserts an item at a specific position.
# delete(obj): Removes all items equal to obj.
# delete_at(index): Removes the item at a specific index.
# 2. Accessing & Information
# length (or size): Returns the number of elements.
# at(index) or [index]: Gets the element at that position.
# first / last: Returns the first or last element.
# include?(obj): Returns true if the object exists in the array.
# index(obj): Returns the index of the first object matching obj.
# empty?: Returns true if the array has no elements.
# 3. Transformation & Iteration
# each { |i| ... }: Standard loop through every item.
# map { |i| ... } (or collect): Creates a new array by applying the block to every element.
# select { |i| ... }: Returns a new array containing only items where the block is true.
# reject { |i| ... }: The opposite of select.
# compact: Removes all nil values.
# flatten: Flattens a nested array (e.g., [[1,2],[3]] becomes [1,2,3]).
# uniq: Removes duplicate values.
# 4. Sorting & Reordering
# sort: Returns a sorted version of the array.
# reverse: Reverses the order of the array.
# shuffle: Randomizes the order.
# sample: Picks a random element from the array.
# 5. Utility & Conversion
# join(separator): Converts the array into a String (very useful for Flowstone's String outputs).
# to_s: Converts the array to its string representation.
# concat(other_array): Merges two arrays together.
# ------------------LOOPS
@array =[] if @array == nil
@array.each do |item|
# Do something with item
10.times do |i|
# Runs 10 times (i goes from 0 to 9)
(0..100).step(10) do |i|
# i will be 0, 10, 20...
# ------------------INIT AND NILERRORS
# All full code must have init and nilerrors- this is mandatory
# All instance variables must be present in init and nilerrors
def init
@array = []
def nilerrors
@array = [] if @array == nil
# ------------------SYNTAX AND CODE STYLE
# Do not write like this..
def isInMousePoint x,y; true; end
# Instead write
true
# ------------------DRAWING
# In order to draw you need to create a Pen.new or Brush.new
myPen = Pen.new @col1, 1 # Draws lines/borders
myBrush = Brush.new @col1 # Draws solid shapes
def draw v
drawRectangle myPen, [0,0,10,10]
# DO NOT ATTEMP fillRectangle/fillEllipse---your code will be rejected.
#------------------DRAWING OPTIONS-----------------------
# drawRectangle instrument, rect
# drawRoundRect instrument, rect, corner
# drawEllipse instrument, rect
# drawPie instrument, rect, startAngle, sweepAngle
# drawPolygon instrument, points
# drawClosedCurve instrument, points
# drawLine instrument, point1, point2
# drawArc instrument, rect, startAngle, sweepAngle
# drawCurve instrument, points
# drawBeziers instrument, points
# drawLines instrument, points
#----------------------DRAWLING STRINGS--------------
def draw v
font = Font.new “Arial”,1.2,”normal”
sf = StringFormat.new
sf.setAlignment “center”
sf.setLineAlignment “far”
v.drawString "Hullo", font,sf,[0,0,10,10],mypen
#----------------------DRAWLING BITMAP--------------
def draw v
@vw = getViewSize(0)
@vh = getViewSize(1)
sf = 12
v.drawBitmap @bitmap,[0,0,@vw/sf,@vh/sf]
#---------------------DRAWING BITMAP SECTION----------------
def draw v
@vw = v.width
@vh = v.height
v.drawBitmapSection @Bitmap, [0, 0, 140, 154], [0, 0, @vw/8.0, @vh/8.0]
#----------------------DRAWLING GRAPHICS PATHS--------------
# Graphics paths in FSR are known to be unstabe and not recommended
# Best to avoid, but if you have to, Use with caution.
def draw(v)
# ---------------- RECTANGLE ----------------
rect = GraphicsPath.new
rect.addRectangle [-4,-3,8,6]
v.translateTransform 20,20
v.rotateTransform @angle
v.drawPath @col1, rect
v.resetTransform
# ---------------- ELLIPSE ----------------
ell = GraphicsPath.new
ell.addEllipse [-4,-4,8,8]
v.translateTransform 40,20
v.rotateTransform -@angle
v.drawPath @col2, ell
v.resetTransform
# ---------------- PIE ----------------
pie = GraphicsPath.new
pie.addPie [-5,-5,10,10],0,120
v.translateTransform 60,20
v.drawPath @col3, pie
v.resetTransform
# ---------------- POLYGON ----------------
poly = GraphicsPath.new
poly.addPolygon [[0,-5],[5,0],[0,5],[-5,0]]
v.translateTransform 80,20
v.drawPath @col4, poly
v.resetTransform
# ---------------- CLOSED CURVE ----------------
curve = GraphicsPath.new
curve.addClosedCurve [[0,-5],[5,-2],[3,5],[-3,5],[-5,-2]]
v.translateTransform 100,20
v.drawPath @col5, curve
v.resetTransform
# ---------------- LINE ----------------
line = GraphicsPath.new
line.addLine [-5,0],[5,0]
v.translateTransform 20,45
v.drawPath @col6, line
v.resetTransform
# ---------------- ARC ----------------
arc = GraphicsPath.new
arc.addArc [-5,-5,10,10],0,180
v.translateTransform 40,45
v.drawPath @col1, arc
v.resetTransform
# ---------------- CURVE ----------------
curve2 = GraphicsPath.new
curve2.addCurve [[-5,0],[-2,-5],[2,5],[5,0]]
v.translateTransform 60,45
v.drawPath @col2, curve2
v.resetTransform
# ---------------- BEZIERS ----------------
bez = GraphicsPath.new
bez.addBeziers [[-5,0],[-5,-5],[5,-5],[5,0]]
v.translateTransform 80,45
v.drawPath @col3, bez
v.resetTransform
# ---------------- LINES ----------------
lines = GraphicsPath.new
lines.addLines [[-5,-5],[5,-5],[5,5],[-5,5]]
lines.closeFigure
v.translateTransform 100,45
v.drawPath @col4, lines
v.resetTransform
# ---------------- ADDPATH ----------------
p1 = GraphicsPath.new
p1.addEllipse [-3,-3,6,6]
p2 = GraphicsPath.new
p2.addRectangle [-6,-1,12,2]
p1.addPath p2,true
v.translateTransform 60,75
v.drawPath @col5, p1
v.resetTransform
#----------------------- VIEW------------------
def draw v
# or
@vw = v.vidth
@vh = v.height
#-------------TROUBLESHOOTING/DEBUG
# When there is a problem many hours can be wasted
# in troublshooting in the wrong areas.
# Finding the problem and going inside the problem
# is better than looking externaly.
#-----EXAMPLE - HOW TO DRAW A RESIZABLE GRID-----
def draw v
@vw = getViewSize[0]
@vh = getViewSize[1]
@sizex = 4
@sizey = 4
@points = @vw/@sizex
@points2 = @vh/@sizey
@px = Array.new(@sizex ) { |e| e = e * @points }
@py = Array.new(@sizey ) { |e| e = e * @points2 }
pen_back = Pen.new @col1,0.2
@grid = Array.new
@py.each do |y|
@px.each do |x|
@grid << [x,y,@px[1],@py[1]]
@grid.length.times do |x|
v.drawRectangle pen_back,[@grid[x][0],@grid [x][1],@px[1],@py[1]]
#-EXAMPLE - HOW TO DRAW A RESIZEABLE GRID WITH BLACK/WHITE CHECKERBOARD----------
def draw v
# SET TO 8 FOR CHESS
@sizex = 8
@sizey = 8
@points = @vw / @sizex.to_f
@points2 = @vh / @sizey.to_f
@px = Array.new(@sizex) { |e| e * @points }
@py = Array.new(@sizey) { |e| e * @points2 }
# BRUSHES (Solid Fill)
b_dark = Brush.new @col1
b_light = Brush.new @col2
@grid = []
@py.each_with_index do |y, row|
@px.each_with_index do |x, col|
# We store [x, y, width, height, color_toggle]
color_toggle = (row + col) % 2
@grid << [x, y, @points, @points2, color_toggle]
@grid.length.times do |i|
# Pick light brush if toggle is 0, dark if 1
brush = (@grid[i][4] == 0) ? b_light : b_dark
v.drawRectangle brush, [@grid[i][0], @grid[i][1], @grid[i][2], @grid[i][3]]
#---------------USEFUL INFO----------------------
# This API has successfully created,
# 1. Game of Life
# 2. Asteroids
# 3. Tetris
# 4. Space Invaders
# 5. Snakes and Ladders
# 6. Minesweeper
# 7. Reversi
# 8. Combat
# 9. Battleship
# 10. Snooker
# 11. Pacman
# 12. Pinball
# 13. Checkers
# 14. Breakout
# 15. Knob maker
# 16. Chess
# 17. Chess_Pro
# 18. Chess_3
# Do not deviate from this API.
# FSR is a HOSTILE enviroment, if there's anything wrong,
# we get red errors.
# I have 20 years experience coding FSR. Listen to my instructions.
########################################################- Attachments
- Schematic_FSR BRAIN API.fsm
- (4.52 KiB) Downloaded 2672 times
