SM prims can be used can't be added to FS toolbox
Here is a strange situation. There are primitives from synthmaker, that can be used in flowstone, but you can't add them to the toolbox. Are there more like these?
BTW, can somebody make a schematic with modules, that are in SM, but were not added to FS?
prims.fsm
(217 Bytes) Downloaded 1045 times
MyCo
Re: SM prims can be used can't be added to FS toolbox
Post by MyCo »
You can't add primitives to the toolbox (regardless where they are from). If you want to add them, put them into a module and add the module to the toolbox
I see, my mistake.
Are there more prims missing in FS?
Over at the SM forum, it was posted, ...
by malc on Thu Sep 20, 2012 3:37 pm
3. There won't be any automatic migration. You'll need to manually move the .hom files or put your modules in a schematic, load them into FS and drag them to the toolbox. It *shouldn't* be too much work.
Does this work manually moving the .hom files ?
MyCo
Post by MyCo »
tester wrote:I see, my mistake.
I don't know... Since I work with it, the only primitive that I've missed was the FFT-Window that you mentioned.
RJHollins wrote:Does this work manually moving the .hom files ?
Yes it works, but don't know if they are getting the right Tags in FS. But when I need to port something from SM to FS, I just open a SM Schematic and copy the parts that I need.
