5x CrossFader
5x CrossFader
I know I don't contribute many examples to the forum - I promise that is changing. When you are developing anti-gravitational wave modulators and flux capacitors - you have to be careful what you share with the profane !
First up: A simple 5x crossfader. It crossfades 5 different streams in a linear fashion. One could elaborate on the idea and add it to attain Nth inputs if they so choose to.
https://www.dropbox.com/s/8cxc3razlbpoz ... s.fsm?dl=0
Peace !
~ That Guy
Peace !
~ That Guy
Re: 5x CrossFader
Could this be used to crossfade between waveforms ?
Thank you btw.
Thank you btw.
Re: 5x CrossFader
Array To Poly > Poly To Crossfade > Poly To Graph > Input on Osc
Be sure to connect all arrays to tick inputs so it updates as array changes.
Try it with the wave draw osc, just treat the load/save inside the module as ins/outs.
If you make a larger Crossfader to Slide thru more inputs, please share here.
Re: 5x CrossFader
Thanks guyman
