Why its ticking ?
Urnsoft
Why its ticking ?
Post by Urnsoft »
Hi Flows
Can someone explain this to me
Why it's ticking !?
I realized encapsulated MGUI is responsible !
Why it's always running.fsm
(35.59 KiB) Downloaded 1146 times
P.S
same behavior with Fonts,Brushes and Pens
the tick rate is approximately equal to 0.01 sec
Have a good day
chackl
Re: Why its ticking ?
Post by chackl »
Evertytime the View is changed it will trigger.
If you pack the MGUI Module and the ruby code to an extra module and ouput the trigger out of the module it will also trigger.
Everytime the Modul-Vie is vidible on screen and you move the view in flowstone it will trigger.
Regards
Urnsoft
Post by Urnsoft »
Hi chackl
You're right about packing the whole thing into module
and I know if the view changed it will trigger.
But as you can see there is no change in the view and its still triggering
I don't get this ,it acts like a ticker and burst every 0.01 sec(no redraw)
Is there a way to limit this process ?
P.S
did you get that trigger burst on your system ?
Post by Nubeat7 »
it doesn`t trigger by itself here!
MyCo
Post by MyCo »
It triggers, when you hover over connections. That's because FS redraws the screen when you hover over interactive parts to highlight it.
In the first example, it is triggering just because the view is visible. You can collapse the module and it stops happening.
Urnsoft
Post by Urnsoft »
Well,It seems its in FS nature :|
Thank you all for taking time on this one
