Finally did the FS v:3.06 update
Having put off the update of FS from v3.04 ... and noticing that many example schematics posted would sometimes
have a RUBY error message. To be expected when running an older version.
Other than that, 3.04 was running pretty good.
Re-reading the Version History, I noticed bug fixes to a couple things I was having .
Spogg supplied me a REG edit that allows 'switching' versions with dual installs. So I went for it.
v:3.06 does seem to be snappier ... but I'm finding an issue with several of my old projects with RUBY.
I load in the old project ... track down the RUBY error box, and find a similar error message showing up:
NoMethodError: undefined method 'xxx' for "" String [for example].
The weird part ? I've a habit of leaving a RUBY box inside a module that was either an example or a testing I was doing. BUT ... they are not actually tied into the schematic ... just sittin' there doing nuthing.
I tried turning OFF the Ruby box ... but that doesn't seem to matter ... the module will still lite up with the Red dotted outline. So ... I delete the unused Ruby.
Other times, it seems I have to Re-Initialize a line of Ruby code. I REM it [#], then un-# and the error message is gone ... then all good.
So the question be ... have you guys had similar experience like this ?? If so ... is there a better/faster way to get RUBY straightened out ?
Any insight, suggestions, shared sympathies would be welcomed.
Thanks !
Thanks !
