Server in .exe issue *FIXED*
Morph
Post by Morph »
Hi, i can not make the Network Server module work when exported to .exe, it just won't start and seems not even try to connect. It do work inside FS, also Network Client works in .exe but not the server or am i missing something?
sal
Re: Server in .exe issue
Post by sal »
hello,
same problem here.
Sometimes It doesn't start inside Flowstone too(try to push start several times and it will fail to start).
S.
DSP
Post by DSP »
I have it working inside an EXE?
Morph
Post by Morph »
DSP wrote:I have it working inside an EXE?
Is this test .exe working for you, DSP? TEST Server
Inside:
sal
Post by sal »
it doesn't work here.
There is something to be fixed on the server module.
S.
TomC
Post by TomC »
Morph wrote:Hi, i can not make the Network Server module work when exported to .exe, it just won't start and seems not even try to connect. It do work inside FS, also Network Client works in .exe but not the server or am i missing something?
Did you exit FlowStone before starting the executable?
Because, if not, the server inside FS is still using the selected port numbers, thus rendering those ports unusable for anyone else, including FS executables.
Tom
Morph
Post by Morph »
TomC wrote: Did you exit FlowStone before starting the executable?
Yes, had tried on other computers too, with no FS installed. No network activity.
Try my test .EXE. Is it working for you?
