Last Switch(Ruby)
Last Switch(Ruby)
Had lots of silly attempts at this over last few weeks...
have stripped it down to this....
I want it to behave just like the standard "green" Last Switch.
Seems to work right...but it's a real important part...and I've stuffed it up a few times now...
so I want to make sure...before i stick a few hundred in my schematic..
Can anyone see a problem with this code....??
Is there a better way...?
def event i,v
if i==0 then
output 0,@firstsignal
if i==1 then
output 0,@secondsignal
endI want it to behave just like the standard "green" Last Switch.
Re: Last Switch(Ruby)
I think the inputs will sum MyCo?
Bill, I have done exactly the same thing,
I think it works fine.
Great.....thanks guys.
Works great Myco....
I thought the inputs would needed to be declared individually....
I had no idea i could get away with that..
oh ok sorry-
I don't know what i was thinking there
That's neat as MyCO, will use it too
Ahhh ... for the 'slow' learner crowd ... apparently me
I tried a very simple input [ 0 or 1], along with inputs for the the 2 variables ... I could not get this to work consistently
This seems that this should be a simple choice and path through the code ... If 'this' ... this, if 'that' .... that.
How I'm screwing this up is ridiculous .... I'm embarrassed, but can someone shed light on this please
Thanks.
Thanks.
Here are 3 variations, 2 of Bill's and the MyCo one.
I think the problem u had was not naming the inputs.
np with asking- it's how I finally cottoned onto this program a little
Thanks Nix !!
It was the 'Trigger'
I had mine similar to your 2nd example ... BUT ... I also had a 3rd INPUT variable (i).
Obviously, still struggling to get a handle on the basics of RUBY. I'm hitting those posted RUBY sites to get familiar. My only programming 'experience' was using GFABasic on the ATARI ST back in the 80's.
When I looked at this "Last Switch', I saw an input [i], and 2 result variables. So on the left side of the RUBY box, I had 3 string inputs [labeled] ... i, firstsignal, secondsignal. I thought changing i from 0 to 1 would toggle the output through the IFTHENELSE routine.
Still don;t understand why this didn't work ... also [now] not sure what the 'DEF event i,v' is really doing. I thought this was telling RUBY to watch for 'i' and output to 'v'.
ahhh ... soooo much more to learn.
