ARRAY Search [RUBY] ??
Wow, was hoping that I was getting a little more handle with RUBY ... apparently, 'almost' is still only good in horseshoes
Have made 'some' progress ... like parsing down an XML file that contains 'patch presets' for programs I'm working on. With the latest discovery of these files, it now seems possible that I can use this XML file to create all the patch names and PRG numbers I need, instead of manually assembling them
I'm experimenting with some ideas to see what the better course to take in doing this.
I have a 'working' module that dissects the XML file into 2 separate arrays. One is the 'patch name', the other is its' 'patch number' [MIDI].
I need to get this full list [maybe 100 or so], organized into related groups [by name], and maintain a reference to its patch number. These 'groups' will feed a 'pull down menu' selector, allowing the User to select a patch from a specific 'bank'.
I was thinking that a 'Search Array' routine would be helpful in putting these groups together. Which has, thus-ly, led to much brain abuse
I've been going through RUBY sites trying to get a handle on this ... only to ALMOST get it working .... or completely NOT working with errors messages that I think RUBY is starting to make up
it's ridiculous I tell ya
I thought that a 'Search' routine that would find ANY character in the array list would output the full name it was contained in [along with its index number]. As more characters are added, the output list would narrow down to the prime candidates. But man, I've not gotten anything working [Ruby wise]. I did find a 'Green' module that kinda works, but it is not finding/matching with only part of a string .... it basically needs the full name ... and it is CASE sensitive, which adds to the problem.
I think I can do this with a single dimension array ... as the dual attempt really got nowhere [for my attempts].
Any bones that could be tossed this way to help would be most appreciated ! I'm going to try and reduce my 'Xperiment Schematic' to something manageable and readable ... but right now it's a conglomerate of all type of trials ... not pretty
off we go ....
off we go ....
Re: ARRAY Search [RUBY] ??
maybe something like this?
- search words.fsm
- (391 Bytes) Downloaded 1204 times
http://julioterra.com/journal/2011/10/l ... sh-tables/
http://ruby.about.com/od/rubyfeatures/a/hashes.htm
but i`m not very familiar with hashtables,
I mean .... that one line does what about a dozen Prims takeNubeat7 wrote:maybe something like this?
I was trying things like RUBY's find_all, or grep commands. [and probably several others I think]
I also see my additional confusion .... what the difference between @in and @ins is ???
Anyway, this core search works Nubeat .... Thank-you!
I'm still will need to figure out outputting the related INDEX number to the found string.
Also, I will need to make it NOT 'case sensitive' on the search.
Oh ... a question ... in the code ' |s| s.include? ' ... what does the variable 's' represent ??
Thanks again Nubeat ... I have so much very basics still to understand.
I've tried to tap into NuBeat's code to also include an INDEX number of all found strings in the Array ... but no success
The only way I could do this is:
However, this version only finds an exact match. It is also case sensitive. During the enter of search string I see error message in the Ruby interpreter.
I just can't figure out how to include an 'Index' of all strings found [as a separate OUTPUT], as in NuBeat's example.
Then to make it NOT case sensitive.
Still pouring through more Ruby instruction sites, but could really use more help.
Thanks everyone !!
array = @in
array.index @search
output 0, array[(array.index @search)]
output 1, (array.index @search)I just can't figure out how to include an 'Index' of all strings found [as a separate OUTPUT], as in NuBeat's example.
Thanks everyone !!
Don't know what exactly you are trying to do but this will search array and return index of ellement you search
so output will be: 1
a = ["test1","test2","test3","test4"]
a.index{|s| s.include?("test2")}Re: ARRAY Search [RUBY] ??
TrojakEW wrote:Don't know what exactly you are trying to do but this will search array and return index of ellement you search
so output will be: 1Code: Select all
a = ["test1","test2","test3","test4"] a.index{|s| s.include?("test2")}
I ask myself that oftenDon't know what exactly you are trying to do
What I'm trying to get ...
I have 2 Inputs ... an ARRAY with a list of patch names. The 2nd input is the 'Search' string.
For the Output, I need a list of all Patch names that contain the search string. Exactly as NuBeat's code does.
I also need a separate Array Output of all the Index numbers to the found list.
To this end, I've been trying several Ruby commands ... even looking into 'Hash' ... but have not been able to get this to work.
With NuBeats search code:
output @in.select {|s| s.include? @search}Getting rid of the 'case sensitive' search I'll try to solve afterward.
As I'm trying to learn, I realize that RUBY is a powerful language. It can sometimes be condensed to very tight coding. Unfortunately, for the amateur, this can make it more difficult to understand or modify. Of course, it is on me to get more experience and understanding. In that pursuit, I sincerely appreciate the knowledge that is shared across the forum.
Thanks !!
- trogluddite
Keys to solving this, I think, are...
- Get all the information into a single data structure
- Test strings using regular expressions - they take some learning, but are super versatile.
Something like this...
Welcome back Trog!
or something like this. it will search for string and return array with index and element from input array
a = ["preset_test1","test2","preset_test3","test4"]
names = a.select {|x| x =~ /preset/ }
number = a.each_with_index.select { |i, idx| i =~ /preset/}
number.map! { |i| i[1] }
number.zip(names)
