Random Number Limit?
Dugg Funnie
Post by Dugg Funnie »
hey everybody, first post! woohoo!
So, I'm working on a plug-in that will randomly load two effects and assigned parameters to an XY pad. Here's the issue I'm running into:
I have a Random prim that's time seeded and using an AfterLoad prim to trigger the generation (and thus the FX selection/assignment) when the plug-in is loaded. However, I'll only have a grand total of 12 effects to choose from, and given that the random prim generates 0-32767, a good percentage of the time it ends up just loading the last plug-in in the Selector's index. So, what can I do to limit the Random's range to something like 0-12 or anything like that?
CoreStylerz
Re: Random Number Limit?
Post by CoreStylerz »
Try this.
But is an workaround. :lol:
Seed max to 12.fsm
(386 Bytes) Downloaded 947 times
PM me if you are interested.
Much easier to use Ruby.
The randomness is automatically time/process seeded, and to get a random number 0-11 (assuming the FX are zero indexed), you need just one line...
output rand(12)
Yup, that's it, just paste that into a Ruby box and change the input to a trigger and the output to an integer - done!
MyCo
Post by MyCo »
Reduced Rand (MyCo).fsm
(257 Bytes) Downloaded 892 times
Dugg Funnie
/\ Wow. That was simple! Thanks!
