ehm, reading data from web?
Quick question, because either I can't find or don't remember whether it works im FS or not.
How to read data from online webpage?
Something like - type in app http://something.com/data/
and get the online content into FS app (or onto local drive as txt file and then into FS).
MyCo
Re: ehm, reading data from web?
Post by MyCo »
Using HTTPPost Primitive without actually posting something...
Get Website (MyCo).fsm
(6.7 KiB) Downloaded 910 times
Okay, thanks on that. Are there any requirements for either server or directory or type of file (i.e. dynamic php / static htm or something in header within a file or structure or something like that)? I mean - it works where the forum is, but gives error on static html file, I have someone else for dynamic stuff there.
MyCo
Post by MyCo »
Well, the Webserver has to return the content. That's the only limitation that I know. That means you can't use any redirection of requests (Status codes in the 3xx range)
Okay, thanks.
