Bump to Martin
Bump to Martin
Post by k brown »
Hey Martin -
I'd asked this in the Randy updates thread - What I'm getting with this new Spectral Tilt is the volume now increasing when moved off midpoint - can we split the difference to maintain constant level? The new one sends the synth into clipping very readily.
Any thoughts?
Re: Bump to Martin
The problem is: the normalization depends on the spectral distribution of the material. You can adjust it for one case but it will be off for another. I should probably make it configurable. Here is a version with possibly better normalization.
TiltFilter.fsm
(1.42 MiB) Downloaded 1039 times
Re: Bump to Martin
Post by k brown »
Yeah, I suspected that (or something similar) might be the case; curious to give this version a go - thanks again.
guyman
Re: Bump to Martin
Post by guyman »
Yes I also think a tilt filter that let's you choose the center frequency, and tilt +- x db each octave heading out from that frequency would be most ideal. One could then make their own normalization algos to compensate based on their tilting for that specific task.
:D Symmetrical spectral madness.
